Question for frank
Btrent1999@gmail.com
96 force 120 decarb or not I was looking on this site got lots of good info saw a theard on de carb it sead to mix a can of see foam with 3/4 gal of gas and two cly run for 15 mins 2 or 3 times on the lake would decarb my motor motor runs pretty good the guy that had befor me sead he he never decayed it thanks
Frank Acampora
Re: Question for frank
You will get more opinions on this than stars in the sky.
If the engine is running well with no problems and if it has high compression on all cylinders, why bother to do a decarb?
roscoe
why not ?
Its fun to smoke out the neighbors.
fucawi
Banned
I think you said in one of your posts frank that TWC 3 oil tends to de carb the engine as you use it so the question is whats it been run on..for how long etc .....
jerryjerry05
Do a compression test.Any difference between the cylinders?That motor the top/bottom cylinder might read a bit higher than the center two.
If so then maybe a de-carb is in order.
I used Mercury's Power Tune.
Get motor hot.Spray into the cylinders as it runs.Almost causing the motor to stall.
Do this 2 times.Any more and you can strip the oil from the bearings and do dammage.
Then remove the plugs and spray PT into each cylinder.Let set over night.Clean the plugs.
Next day start it up and get it hot.Let run till it stops the extra smoking.
I don't do this unless I'm worried about the compression.
