Question For Kenny 4800 MSL lake
72SideWinderSS
Hi Kenny,
Dale recommended I contact you about High altitude tuning.
I'm headed for Cascade Lake in Idehoe shortly and have a question for you concerning jetting. What jet size would you recommend for a 1979 Johnson 115 hp no mods (yet).
Also I have a 13X19 Michigan Wheel I plan to run there.
Here at sea level I turn that wheel at 5700 rpm.
Thanx,
jimmy
walleyehed
Re: Question For Kenny 4800 MSL lake
Need to drop the mains 3 sizes (.003), advance timing atleast 1-2 degrees above max, and it will likely require a 17P prop.
With the changes above, it may turn 5500 with the 19, but I think you'll be doing good to get 5300....the reason I would suggest the 17P.
Make sure it has the correct, factory sea-level jets before dropping 3 sizes.
72SideWinderSS
Thanx for the info.
If I rember right the carbs have 54c's in them right know, so drop to 51c's or is each number a step of .001" ?
I have a alum 17" that came on the old motor when I bought the boat 10 years ago, kinda used up abit but I have a prop shop close by.
Thanx again,
jimmy
walleyehed
Yes, you can go with .051's or .052's (51C or 52C)
72SideWinderSS
Kenny,
one more quick question.
My plugs are a med brown now, would you recomend I drop down a size or two now, and then drop two or three more when I get to the lake?
thanx,
jimmy
walleyehed
If they are med. brown now, I'd say thats good...they go from med brown to lite tan quick. No, I'd be happy with the med. brown.
72SideWinderSS
Just wanted to thank you Kenny for your help.
Everything worked out just fine. My Daughter, oldest Grandson and myself had a blast.
Thanx,
jimmy
Dhadley
Don't ya just love it when a plan comes together?
