Re: question for lubedude
I agree with Rhadley, I have said before that the automotive regular gear lubes are not up to marine use. I also met with some replies that it was the same. (It is not). I would refill it with a synthetic gear lube, in this case the automotive SYNTHETIC gear lubes are fine. Use a GL 4, unless your outdrive specifies a GL 5. Some GL 5s will damage yellow metals, (brass), I do not know if there are brass parts in a lower unit or not so that is why I say this. If the oil says, GL4-GL5 then it is fine to use.<br /><br />Now, after aying all of that, I seriously doubt that if you just put a very small amount in to "top it off" Like just a few onces, you are probably ok. But you notice I said "Probably". I would still change it when I got a chance.
