question for rodbolt
frankie
have you any clue as how far to turn the rod next to the spleen to get reverse action on a yam 70b.If you could help it would be most apreciated. thanks.
rodbolt
Re: question for rodbolt
something about 20* from the nuetral detent you will have one gear or the other, always rotate either the drive shaft or prop shaft any time your shifting as the shift mechanism can be damaged if you dont.
