Question for Tabman
cuzner
I just instaled atc for my tabs.Had some other issues to work out( resevoir empty :eek: )but it seemed they where over-reacting.I own a 94 sundancer 23ft (aftcabin) and instaled the sensor under the helm seat. My question is did I instal it too high, should I have mounted it in the engine compartment, closer to the water line?That was the first thing that came to mind( before I noticed resevoir level).Just wanted to cover all my bases before I head out to the marina.<br /><br /> Jim
Tabman
iboats.com Partner
Re: Question for Tabman
Jim,<br /><br />No the location of the sensor is fine. I would suggest that when you set the zero point let the bow come up a degree or two from where the boat is running normally as this will likley make the system a little less "squirly".<br /><br />Let me know the outcome,<br /><br />Tom<br />Bennett Marine
cuzner
Hey Tom thanks for the quik reply!!<br /><br /> Jim
