J70ELCIM, 1981 70hp 3 cyl.
I think I have run into something I have not seen yet. I have good spark, compression is 135, 120, 135. I have rebuilt the carbs. The problem is that it only idles at 6-8 degrees BTDC. CORRECTION BTDC If you retard the timing slowly back toward TDC, it will stall. All this in neutral.
OK, so I did a cylinder drop test. #1 affects the idle slightly, #2 about the same, and #3 kills the motor.
All the time for these tests, the engine is running at 1200 rpm. Won't reliably go any slower.
Drop it in gear, and it really bogs the motor down, and it stalls within 10 secs.
I have a slight fuel drip from the front of #1 carb. I have changed that carb with another one, and still drips.
All of this is leading me to the conclusion that #1 and #2 are not contributing. But why? So, I think reeds, and then I thought crank seal ring between #1 and #2.
My question.....how can I absolutely test the crank seal between #1 and #2, (or maybe even the gelseal) between the two crankcases (#1 and #2) to eliminate that as an issue?
It seems as if the two upper cyls are not getting the same fuel charge as the bottom one. And, the fact that fuel is dripping slowly from the #1 carb says I am getting blow back somehow.
Any of this make sense? Is there an oldtimer's trick?
As always, thanks for your thoughts.
