Re: Question for You??
I take it you are referring to your boat with transom repairs, which I guess are now completed.<br />You really should keep all of your posts with the same question in the same place. Eliminates alot of guessing and you will receive alot more answers.<br />Did you install a jackplate?<br />If not, I would start, with your hull, with the plate about 1" above the bottom of the centerline.<br />Perform all of the tests that we mentioned in your other post and record the results, than post back and we can take it from there.
