Question From Joe Reeves
Joe Reeves
To begin, the powerhead mentioned below in all aspects is identical from 1988 to at least 1991.<br /><br />I recently sold a rebuilt 1991 200hp looper powerhead to a friend that lives a few blocks from me. His engine is 1989 200hp looper and he is in the process of changing the powerheads over at this time.<br /><br />He phoned me and stated that his engine does not have the same type thermostat covers, and that his thermostat covers do not have any fittings at all where water hoses would be connected.<br /><br />In all the engines of this class that I have worked on in the past (V6 Loopers), the port thermostat cover had one hose fitting and the starboard thermostat cover had two hose fittings.<br /><br />This morning I checked my books, going from 1988 to 1992 to eliminate leaning on memory and I found that indeed all of the thermostats incorporated the hose fittings on both thermostat covers, and all had the well known Water Control Valve Assy. My friend says that his engine does not have this Water Control Valve Assy.<br /><br />The control valve I speak of is behind and operated by the vertical throttle arm that operates the timer base etc.<br /><br />I know that a different type water control assembly was used later on at the top portion of the exhaust baffle area somewhere, but my friend says that this newer control does not exist on his engine either.<br /><br />I may be missing something as I did retire in 1991 and of course had no access to service bulletins since. Does a conversion setup of some kind exist whereas the Water Control Valve and its related hoses are eliminated?
Walker
Re: Question From Joe Reeves
Joe, didn't the V4 loopers start out with the water control assembly and then change to just plain thermostat covers, Maybe the V6's did the same and somebody already changed his over to the new style.
dcolpitts
I have a 1986 140 looper that has been converted from the water control to with out. The numbers I have on record were a post dhadley sent me. I'm not sure that the numbers I have macth the v6's but the share some parts. The parts need to be from a 1992 or newer. I can give the #'s but I think the t-stats might be of a differant size. The ones I used for trhe v4 were<br /><br />333967 cover<br />329830 gasket<br />333858 spring<br />2 each<br /><br />you should arlready have<br /><br />43137 tstat<br />320880 seat<br />330272 cap(keeps seat in place<br /><br />I don't know that the stat and cover #s are the same but this might help( or confuse ) it worked on my v4 looper
Joe Reeves
I appreciate the replies, thank you. If anyone has the bulletin pertaining to this conversion, I'd appreciate having a copy of it. My email address follows.
