Question from SADDAM HUSSEIN - Viking 6hp Motor
buradori
Hi, I am running from the allies and I just bought a Viking 6hp motor in great shape. The Gas/Oil mix chart on the gas tank has worn off so I can't read it. Anyone know what it should be? Here are the particulars:<br /><br />Viking 6hp<br />Built in 1969<br />Model 64901<br /><br />Also, if anyone knows the branded equivalent or where I can get a manual, that would be great! I need to move again now. Bye!<br />Thanks,<br />Saddam
KennyKenCan
Re: Question from SADDAM HUSSEIN - Viking 6hp Motor
Had one of those Saddam, the oil ratio should 300:1.<br /><br />I had a shop manual for it once too, but it was in my office in the World Trade Center.
SeaMasterZ@aol.com
heres a simple test<br /><br />take six gallons of gas<br /><br />add one quart of oil<br /><br />shake vigorously<br /><br />take a Strike anywhere match and scrape it against the opening in the tank, - the flaring will indicate the proper oil mix, dim flare equals too much oil, store in open buckets till needed and add more gas<br /><br />be sure you have a good close look at the tank opening when you do so<br /><br />Enjoy the 72 virgins in what ever the islamic version of hell is<br /><br />::waving bye bye::
ledgefinder
Ensign
Hi Viking-<br /><br />Did you try AOMCI (I think it's antique outboard motor something, and www.aomci.com). They'll know right off.
