SanityCheck-27
- Joined
- Jan 13, 2014
- 7
I've done compression test before on other engines but was told I could damage the computer modules by not grounding the sparks plug leads first before running the compression test. Is this correct and should I just run a wire lead from each spark plug lead to the engine block?. The engine is a 250 hp Yamaha 4 stroke 2007 not sure what the compression should be on this engine. Thank you for the help Robert
