Question on crank case pulls fitting.
JC1933
Does this fitting have a check valve?<br /><br /> I have a new fitting that i can blow through from both ends, yet there seems to be some kind of plate or valve inside, is this defective?<br /><br /> thanks in advance...Claude.. :)
Dhadley
Re: Question on crank case pulls fitting.
It cant be a check valve. It has to let the pulse go both ways to operate the pump. The metal piece is a flame arrestor so it wont burn the diaphram in the pump.
JC1933
Thanks Dhadley,<br /><br /> You are fast on the trigger as usual.<br /><br /> So i see there is nothing wrong with this connection. ;)
Dhadley
You should be good to go. This is on the 130, right?
JC1933
Yes it is on my 130.<br /><br /> Got the new OMS pump, my old pump was starting to seep fuel out of the top must be a small crack or something. thanks. Claude.
