I'm re-installing my drive shaft housing on my 1987 alpha one, pre-Gen2 drive. Somewhere I read that if the splines don't line up, I can turn the prop counter-clockwise which should turn the spline so that it meshes correctly. When I turn the prop counter-clockwise, the u-joint assembly does not move and the prop turns freely. I'm wondering if I might have accidentally changed something when I was moving the drive around while off the boat or something. The gearshift was in forward when I removed the drive.
Should the prop and drive shaft be engaged with each other?
Do I need to do something to engage them before I re-install the housing? If so, can someone tell me what? I hope it doesn't require disassembling the out-drive.
Thanks for the help so far.
