Question on getting new control cables
jtrom
Time to get new control cables for my '74 Johnson 50. These cables and motor did not come with this boat so it is kind of a guessing game. How does this cable loop look at the motor? Should I order cables an extra foot longer?
bonz_d
Re: Question on getting new control cables
Looks good from here. As long as the cables are not being pulled tight when the engine is turned all the way I wouldn't change length.
tazrig
^^^+1 the length looks fine. Unless, as stated above, they are being pulled into a tight bend causing them to bind when you crank the engine hard over you should be fine.
