Question on install of Suzuki tach with warning lights. Help please?
merryacht
I am installing a Suzuki Tach (used) which has warning lights included.
They are:
check engine
temp
oil
Rev (limit)
I have figured out the back-light wires, which are red/green and black. I also know the yellow tach wire, plus the grey (+) and black(-) wires, but there are 4 more wires that I assume run the warning lights. My question is what does each color wire operate within (I assume) the 4 warning lights and can they be utilized by me with my 1987 DT 85?
The colors are:
pink
green and yellow
green and white
blue and black
They all come together in a 4 wire male harness.
Thanks in advance for the help, this is a wonderful site, filled with great people with great advice.
adibubu
Re: Question on install of Suzuki tach with warning lights. Help please?
Hello,
If you do not find till now what you need...If you find, maybe others will need it...
Here is a small picture to clear the problem:
ralphl
would this be the correct diagram for a 96 DT 55 oil injected two stroke?? If not where can I find that schematic?? Dont mean to hijack the thread but it is related
