Question on plug plug line on rear of motor
snookhooked
This is something I have seen done on other motors but the question is why? Its on the rear of the block. I cant find my manual to research it and don't know what exact name would be used? I had a older mercury motor that it too had been plugged up.
snookhooked
Re: Question on plug plug line on rear of motor
I guess I am not the only one who doesn't know what its for and if it needs to be fixed. Why its plugged up like it is? I have tried to do research on Crowley motor diagram but it doesn't show both sides to even find a name to research its use.
RogersJetboat454
I'll take a guess...
Is it the water feed to the tell-tale?
snookhooked
Your guess is as good as mine. its never effect the motor but just curious to why it would be plugged up?
RogersJetboat454
OK... put this another way...
Does your motor currently have a working tell tale?
Hopefully an expert will pop in here, and say it's this or that...
Haven't worked on big or newer outboards to give you a solid answer, but that's my educated guess.
classiccat
i'm also a small OB guy but I like guessing :lol:
1st guess: for monitoring water pressure
2nd guess: for flushing w/out muffs
snookhooked
I have always watched to make sure its peeing. I have never really heard the term tell tale to be honest. I replace my impeller every year and never thought much of that tube since everything has always worked fine. It just puzzled me to why and if it needs to have the screw removed that's plugging the hose? I am thinking it must be normal in some ways since it hasn't effected the engine at all to this point. cant really find anything on it through google search.
JB
Do you think you could identify your outboard?? Make, model, HP, etc.??
LongLine
I'm guessing that insufficient water circulates on one side of that piston, i.e. Maybe it's used to eliminate a hot spot.
Tom B.
(LongLine)
snookhooked
Tom B.
(LongLine)
Ok, now your thinking that with it being blocked doesn't allow water to use that hose as an exit? I have never felt the motor get hot at all. even while running it, the water may get at best luke warm. Thats feeling the water from the pee hole while running wot. I can let it run on the hose for 30 minutes and the water doesn't get but warm at best. the heads are warm but never been hot. Does this make any sense? I am more curious than anything when asking this question.
boobie
Somebody maybe had a water pressure gauge on it at one time and then took it off. Pull the hose off, start up the mtr and see if any water pisses out of it.
snookhooked
Never would hurt to see. never bothered with it.lol
emdsapmgr
The normal telltale on that engine comes out of the large rubber (grommet/insert) exhaust relief at the top of the midsection. Think bobbie is correct. In order to plumb a new fitting to drive a remote water pressure guage on that engine, a prior owner has added this nylon hose barb. Since it's no longer used, it looks like that short hose is plugged off at the bottom with a screw and some gasket sealer. As long as it does not leak, it's fine as is.
LongLine
How about the design engineers really didn't know where the tell tale should exit to prevent hot spot so they had the casting made with two possible places. The old story - casting lead time vs completed testing deadline vs production release - schedule type thing.
Maybe the conversation went like this:
"ah nuts, use the other one." :facepalm:
"But we got this one all drilled and tapped" :eek:
"Just plug it, maybe someone will figure out a use for it one day"
"Yeah, maybe someone will want to put a pressure gauge in it or use it as a flushing port" ;)
"Or go nuts on the internet wondering why it's there & plugged." ;)
"We don't have any plugs with that thread."
"Just put an elbow on it with a hose & barb, this thing's got to be in the showroom tomorrow."
:rolleyes:
Tom B.
(LongLine)
snookhooked
That makes good sense. Thanks guys for the input. I have always been curious to it but everything said makes perfect sense. again Thanks.
F_R
Parts list shows a "plug, cylinder head pressure tap". Sure sounds like it is for an accessory water pressure gauge, doesn't it?
EDIT: A check shows several accessory water pressure gauge kits offered in 1992. I reckon that answers the question.
snookhooked
Thats good to know. Crowely didnt show much but Thanks.
