Re: Question on proper trimming
90% of the dealers will try to correct this problem with a prop. First suggestion will be to reduce the pitch. This will allow you to get on plane easier. It will also increase the RPM's at any speed and cost you more fuel. Not something I would want at $3.50 + per gallon.
However; you are trying to run at slower speeds and maintain visibility over the bow. A prop change will not do that. Trim tabs (any brand) extend the hull, and allow you to change the hull configuration (design) to provide more lift (stern) when needed and less when not needed. They do other things as well, but let's stay on point. In short, the hull is adjustable on demand.
Results? Minimal bow rise = no hole = no hole shot. Cruise slower and stay on plane. Run smoother at any speed. Improve handling. Improve fuel economy
