So I just picked up a 1973 Johnson 20R73A 20 hp and had a question on how to start it. I'm pretty sure I know how but need a refresh. What do I set this dial to? And what is it's purpose?
I assume I pull the choke till the motor starts than close it. Right? Also, do I turn the throttle handle up or down to start?
Next questions is; when I hookup the fuel tank line to the motor it leaks like crazy. Can I just bypass the quick connector and run the fuel line straight to the manifold on the fuel pump? I plan to add a valve inline.
Any input would be great.
