Question on stator/rectifier
Darol Wester
I have a 1982 35 hp Evinrude that I put a new stator and rectifier on 6 years ago and parked it in the shop. I'm selling it now and was checking everything out for the buyer. While the motor was running, I tested what was coming to the battery from the stator and it was no different than what the battery had initially. 12.58v. I tested the three wires from the rectifier and they were open one way and closed the other. I also did an ohm test on the 3 wires from the stator with black to ground, red to the wires one at a time(while they were all disconnected) and there was no continuity. I have great spark to the plugs also.
I guess my question is, does the stator only put a charge towards the battery when needed, or what problem might I have here?
jere1972
Re: Question on stator/rectifier
Not an expert but your stator is a coil of sort and you should have a resistance value of some kind, if your stator coils are over 200 ohms most magnetic inductive coils are, continuity testers/ or meters on continuity scale will not show, conitinuity is a relative short, and that is what you do not want to see, try a 2k scale! and no I believe your charging system is variable but continuos
Will Bark
Are the connections(both ends) of your battery cables clean and tight?
Darol Wester
In my Seloc book it shows to test as I did, though I don't have a tester that goes to 2k for the next test. I'll have to find one for more tests.
Yep. I cleaned all connections before testing.
I wish I still had the wiring diagram for the connections of all wires for this, to double check what I did 6 years ago. If anyone can post one, I'd be more than greatful.
