old islander
- Joined
- Jan 27, 2013
- 302
Ok, my lower unit will not stay up. It slowly lowers itself back down. Takes abut 5 minutes to do this. Nothing is leaking and fluid level is full. Bond-o mentioned a while back it might be the check valves in the pump....or bad trim cylinder seals.
My question is two part.
1 can the check valves be replaced without replacing the whole pump assembly?
2 Is there a test I can do to determine if it is the valves or the cylinders?
I find that in a 50 50 situation I all ways go for the wrong one first. Don't want to buy a new pump and find out it's the cylinders....or vice versa.
Boat is a 77 islander with a 120 hp 153CI. inline 4.
Also, what drive would this be in 77?
