Hi all, Alpha one Gen 2 drive behind 4.3 carbed 2003 setup.
This will be my first impeller replacement.
Thanks to everyone here and especially Don S. for many awesome write-ups. I saw the one about impeller replacement. I also have copies of the various shop manuals too.
My question is the mention of using "perfect seal" on the lower small holed gasket. Do I run a bead around the under side of that gasket? or both under and upper sides? And why only that gasket?
Oh, the marina tried to sell me the much more expensive impeller kit that also included the water pump body. I thought this was only necessary if you had the plastic body. Am I being cheap? Or should I not fool around and just get the more expensive kit?
Thanks,
Joe
Thanks,
Joe
