Question Regarding A 85 Hp Force Lower Unit
1fullforce
Hi Guys , Can Anybody Tell Me About How Much A 1987 85 Hp Force Lower Unit Weight? I'm Planning On List It On Ebay This Spring And Im Wondering How To Ship It If Buyer Wants It Shipped. Will Dhl Or Ups Ships Items This Heavy?
Thank You In Advance
Jesse
Frank Acampora
Re: Question Regarding A 85 Hp Force Lower Unit
Don't know exactly but I suppose it weighs about 40 or 50 lbs. DHL and UPS will ship it. You MUST however drain the oil otherwise it is considered hazardous and they will not accept it -- or so I've been told, never tried myself.
phonedrn8
uhm 1full force if u havent listed on e bay I might get it from you. i have a 1989 85 force and might/ will need to replace it this is why
please keep update on
I plan on taking it to a marine mech shop to get the engine a once over, but i got a feeling
javsam
You'll need a special box to ship it,has to be a double wall.My guess once it is all packaged would be 60 pounds.
roadrunnr
I believe 75 pounds is the limit for packages going to a residence, so you should be OK with any of the shippers - UPS, DHL or FedEx Grnd. Make sure it's packaged extremely well, some of these shippers can be gorillas!
1fullforce
thank you guys for all the info, i will let the shipping office do the packaging for me, i know a shipping agency nearby that sells stuff on ebay and they definately can package it for me.
Frank Acampora
Phonedr8: That lower unit is just barely "broken"-in. Yuk Yuk.
Seriously, That skeg is really thin and breaks off easily--One good hit can do it. A new skeg costs about 40 bucks unless you have some heavy duty hard aluminum to cut one from. A welder will charge about 100 bucks for the welding. The front end looks banged up a bit but there is a lot of meat there--you would be surprised how thick it is. It doesn't look like it is leaking. The oil coming down the leg troubles me because I can't see from where it is coming. It could be residual engine oil or it could be gearcase oil. If it smells sulphury it is gearcase oil and you have a leaking seal--probably the top seal under the water pump or the O ring seal on the front of the lower water pump plate. If it smells sharp and sort of gasoliney then it is residual and nothing to worry about.
You need to drain the gearcase anyway to have the skeg welded, so drain it and see if any free water comes out or if the oil is milky in color. Either condition indicates leaking seals (and sometimes it is as simple as leakers on the fill and drain plugs, just tighten them adequately)--or, of course, the worst case--a cracked gearcase.
The prop is repairable--I've seen them WAY worse and fixed, 40-90 buck range, but you may just be better off buying a good used one.
Given the light damage to the prop, I doubt that there is any internal gear damage. There could be, of course, but not very likely.
drewmitch44
Phone how did you do that to you lower unit??? Did someone do that on purpose!!
Digpig
Can't believe that lower unit photo.....I thought I was the only one to have absolutly NO skeg left on my lower unit. I have just purchased the boat and the previous owner said he had no problems running it like that. I'd like to have it replaced for nothing other than the fact I know at some point I'll drag it over a rock or stump !! I'm new to fiberglass boat ownership (86 Bayliner Capri - 85 hp Force outboard) and this is my first post. These forums are going to be a great source of info for me....All that being said.....How do I get this repaired ?
phonedrn8
thats the way I bought the boat what u see is what u get for 500.00 the guy did not say anything about the engine and bumps and bruses or this case driving down the Las Vegas Strip in a boat .
to bee on the safe side
