Re: question
This appears to be going the same way as the other thread that you started about this motor.
Several people chimed in with suggestions and questions in an effort to help you out...(There it was also suggested that compression and spark were the first things to check.)....you ignored these requests for info...when I asked you to answer some of our questions...to help us to help you... you had a hissy fit, and did the forum equivalent of stomping out in a huff...."Unfortunately for me, your curt remarks have left a sour taste in my mouth and I will seek the guidance I need elsewhere."
Everyone in here is more than happy to help you out (I have never experienced such a collective willingness to help out strangers) , but if you appear immune to any good advice that is offered, that urge to assist wanes quickly....
That "old- timey Texan" was just trying to save you $60-. It could well be that you just have a whack of water in the tank which would certainly cause the problems that you are having.
I could offer some advice but it would just be " I bet after this rain you may just have water in the tank. Pump the bulb a few times and look at what comes out"
But I don't want to risk offending you again....so I won't
But if you decide to follow his advice, you should just get a nail, or similar, to depress the ball in the quick connect, pumpthe bulb (you may need 3 hands
) and collect about 2-3" of gas in a clean glass jar....one that is narrow and tall is best.
Let it settle and see how much "gunk" settles out at the bottom.
If it seems clear/clean, siphon some fuel right from the bottom....tilt the tank and draw from the very lowest point. Again, see what settles out.
That will prove the fuel quality or lack thereof.
If I
WERE to offer any advice at this point, it would probably be that you should do this first....then if you find that you do have a load of junk in the fuel, you can drain the bad fuel, replace with fresh, and see if the parts place will take back the carb kits....
