Questions about choke solenoid
TAC_Double
When I bought this engine, the choke solenoid was disconnected. I have been trying to get it working again. What I found was that the plunger spring was missing, and they had disconnected the ground to it.
I have replaced the spring and tested the solenoid as per the manual. When I turn on the key, the plunger goes down in the solenoid and never comes back out. I am not activating the switch for it... it just does it. I am I missing something here? or does it have a mind of it's own. The switch seems to do nothing to it.
1975 85hp Model 85933
darrklim2
Re: Questions about choke solenoid
Maybe that's why it was disconnected? It might be bad?
tashasdaddy
something is wrong in the switch. what year is it. the one where you push the key in or the ones with the separate lever for the choke. choke switch may be shorted.
TAC_Double
It's a 75.... It has a seperate switch under the ignition. I was leaning towards the switch, but I wanted to get some other thoughts in case I was missing something....
ezeke
Look on the top of the engine and see if there is a pair of wires running out of a recessed point adjacent to the lifting eye.
If the wires are there, it is a variable resistor temperature sensor which was supposed to control part of the choke solenoid.
Most of them were disconnected by service departments many years ago, but people have wiring diagrams and service manuals, so they hook 'em up again.
If you have one post back here.
TAC_Double
ezeke,
I did find a sensor that is right behind the power pack. The wiring is next to the lift eye, runs behind it and ends at the terminal strip next to the flywheel.
The wiring is purple, like the choke and terminates on the terminal strip right be the ones I think go to the choke solenoid.
Dhadley
There was a service bulletin out years ago saying to disconnect the wires to the heat sensor. The theory was that it would act as an automatic "half choke" on a cool motor when a full choke was not needed. Sounds good in theory but really wasn't needed. Whether that's the cause of the problem or not it's OK to do away with the wires.
TAC_Double
I will disconnect and see if that helps.
Thanks for your help everyone!
ezeke
I think the service bulletin covers the issue. You may want a copy of a part of the wiring diagram so I will attempt to get that.
The idea is to get the full function of the choke solenoid to the switch on the control and not let the sensor do anything because it never worked right for the most part.
TAC_Double
Ok, so I removed the wiring to the thermo switch.
I have moved the purple/yellow wire from 4 to 1. It says I should add a jumper between 1 and 2.. The other purple wire for the solenoid is on 2 with a brown/white wire.
Should I still add the jumper between 1 and 2 or could I just put the purple/yellow on #2?
ezeke
That should do it, the original solenoid had two circuits, so they wanted all the power for both to come from the control switch after the change:
TAC_Double
Ok, this choke switch is now working as it should. Still having troubles with the solenoid plunger sticking down. The plunger is a little rusty, going to try and clean it up and see if it works.
Thanks for all of the help everyone!
Dhadley
Assuming the return spring is still there, and is the correct one, the plunger may just require some cleaning.
tashasdaddy
clean it up and some 3 in 1 oil.
ezeke
Never oil the plunger on the choke solenoid. It should be bone dry all of the time. It is supposed to be stainless steel. If it is dirty or oily, clean the core and the plunger. See page 3-9 in your service manual - "Automatic Choke".
Adjust the choke solenoid by moving the whole unit up and down in small increments, not by stretching or cutting the spring.
TAC_Double
Well, I cleaned the plunger and It is working great. The switch on the control is working now, and I am a very happy guy!
Thank you all for your help!
