I have two 90 model 200 hp evinrudes, set up one standard and one counter rotation.
The 200 with the standard rotation will turn 6000 rpm at wot no problems. For reasons not stated, I put the counter rotation lower unit on the same motor and it will only turn 4800 rpm at wot. The two props are from the same mfg, dia and pitch the same. Only difference is one is standard rotation and the other is counter rotating.
Today I pulled both lower units off and checked the ratio by putting them in gear and rotating the prop while counting the turns of the shaft. For one turn of the prop the standard rotating unit turns 1.8/1.9 times. For one turn of the prop the counter rotating unit turns 1.75 times.
Both units turns freely, no binding, no water in oil, shifts good, etc.
Could the difference in ratio cause a 1200 drop in rpms at wot?
I have been fighting this difference in rpms for about two years and hope this is the answer.
