So I finally got the boat out today. Could not get it to stay running at idle, would always stall. Also it felt underpowered throughout the spectrum. A bit noisy too, more of a thumpy noisy tahtn a tapping or clicking. I did check point gap and set timing prior to taking it out. I may not have any idea what I'm talking about but running rich came to mind.
So I'm going to need to run for a while on muffs while I try and figure this thing out. My SeaDoo XP on muffs should only be run for maybe 15 minutes. Is there a limit like that for my 1989 MCM (GM) 3.0L ?
I know there is a thermostat in the water path, I replaced it. So until the stat opens up where does the water from the muffs go? Can I get too much water or water pressure in or is it a safe system? When it is passing through the thermostat the water then exits through the center of the prop yes? I guess I'm a bit nervous...
Thanks
Mark
Thanks
Mark
