Questions for 4.3 6 OMC Cooling/Outdrive & HP
111torrance111
I trying to figure out exactly what I have for future reference and have a couple of questions.
Question #1:
I have a 1986 4.3 liter engine with a 2 barrel carb, how many HP is this motor?
Question # 2:
The motor was intermittenly overheating, this site recommened removing the termastat and try again. Removing this worked great, now I'll buy a replacement. The problem I have now is how do I refill the water level, I was told the engine uses fresh water for cooling and the raw water cools the fresh. Very confusing.
Question #3:
While checking the uper section of the outdrive I found milky looking oil, I assume water must be getting in somehow. I do hear a cluck when I put it in gear, but while in gear it runs fine. Now I don't want touse it until I get the oil/water problem fixed. While calling around for prices they want to what modle outdrive, I tell them it's an OMC800 but there looking for more information such as Cobra or another name. My outdrive has a gear on the outside to raise/lower, is there something I can look for to give me the coorect modle#
Sorry for running on, but this stuff can be confusing.
Jerry
sundowner205
Re: Questions for 4.3 6 OMC Cooling/Outdrive & HP
I believe that is an OMC 800 drive, from the "gear" that you refer to.
Gary H NC
Cobra drives never had that gear...you have a Stringer drive..( Pre Cobra)
I bet the drive and engine was a 1985 although the boat is a 1986.
Not uncommon for the factory to use a year prior engine-drive setup.
Thats a non-Vortec 4.3. I think the HP rating with a 2bbl carb is around
180hp.
Post the motor and drive serial numbers and a few of the guys may look it up.
Oh,and don't use it until the leak in the gearcase is fixed..
180shabah
If you were able to tell the mechanic that it is an OMC 800, and he had no idea what you were talking about, then you need to find a different mechanic to do the work.
2bbl pre-vortec 4.3 makes about 155-160hp at the prop - more at the crank.
111torrance111
Thanks group,
Now what about the cooling question, does this motor use both raw (I'm assuming this means salt water) & fresh water to cool the engine? If yes I don't see where fresh water can be added or checked.
Jerry
180shabah
Could be either raw ro fresh water cooled, they came both ways. Is there a heat exchanger? If not it is a simple RWC system. If you have doubts, post a picture.
