Hi
I am assembling the above engine (No manual) at the moment and I have two questions.
1: The small strips of gasket between the crankcase half's have me pussled. The are slightly larger on one side and there is a small strip of adhesive in the one side. Should they be mounted upright, so that they are much higher than apparently needed and a lot of crush. or should they be mounted lying down, where i cant see the point of the adhesive?
2:Secondly i need the torque settings for the crankase bolts?
I know, I probably should buy the manual, but Its a "quick fix"
R
R
