skunkedskippy
- Joined
- Apr 30, 2017
- 130
I'm replacing the fuel tank, hoses, fill, vent, etc on my 1977 Skipjack 24 open. I believe everything is original equipment. The fill is grounded to the tank, and the tank grounded to the battery, via the sender, I believe.
If I replace the tank with a plastic unit do I still need to ground the fill?
The current fill hose is clamped to a copper 90? elbow below the deck. Is copper a suitable material for fuel lines? Or, are "modern" hoses able to bend 90? without kinking?
While shopping online for hoses I noticed that most fill hoses are A2 and and vent hoses are A1. Is this considered the current "standard" for hoses? I would think the higher fire rated A1 would be better for both hoses.
Thanks in advance for your help. I'll probably have many more questions as I go forward with this project.
