ok, so i finally found a tach that claims to work with my 1973 chrysler 70hp. but, when really reading into this thing, it claims to not be able to work with magnapower type 1 ignition. i was told this is what i have. the tach lists my model as one that will work with a tach, but then it states it will not work with type 1. my service manual says hooking up a tach is doable, and give directions for an easy hookup. i was also told that this motor has 12 poles, and to set the tach for 6 pulses. so, the question is, can a tach actually work on a type 1 magnapower? looks like it will, but thetach directions make me believe otherwise. will i hurt anything just by trying?
