I'm fairly seriously considering purchasing an older Sea Ray Sundancer. I'm looking at boats that range from $10K up to about $25K, and from 26' to 32'. I'm getting back to boating after a long absence so looking for advice.
If I get real serious about a boat, I'll definitely get it surveyed and possibly have a mechanic check the engines. But I obviously don't want to do that with every boat I consider, so I need to winnow the list down to one or two.
I don't want to drive these poor sellers crazy with 100 questions, so I've tried to think of the pertinent ones. Here's what I've got:
Am I on the right track here? If you were a seller and someone called to ask these questions, would you feel ok about that?
One last question: Suppose I'm looking at two Sundancers that are pretty comparable. One is $20K and has 270 hours on two engines. The other is $10K and has 1000 hours on two engines. Which is the better buy if both are freshwater boats?
My thought was that if the engines seemed ok, I might be able to get at least some use out of them before needing to replace or overhaul them. But I don't know what it costs to replace/overhaul a couple of engines on a boat like this so any advice is greatly appreciated.
Thanks, folks!
- Where is the boat located?
- Is it in the water now?
- Will a sea trial be possible?
- Has it been surveyed recently?
- Has it been used in salt water?
- Has it ever been submerged?
- What engines does it have?
- How old are the engines and how many hours do they have on them?
- Are there any known maintenance problems or issues with the boat?
- What options or accessories are included?
- Does it include a trailer?
Thanks, folks!
