The motor is a late 80s early 90s? 70HP Yamaha 2-stroke CDI 3cyl.
I just went through the carbs, fuel pump and did a compression test. 120PSI on all cylinders and one stuck needle on the bottom carb (fixed now).
The issue I'm having is at part throttle and WOT she stumbles all over itself and won't increase RPMs. It ran great on the first run of the season but after a tank of fuel it started with this issue. It was taken out of commission about two years ago for this same issue, so it's a long term issue that was not caused from my doing.
I believe it's the plug wires though, why? because I get a nice shock if I'm touching the lower wire while it's running AND once the motor has warmed up for a while I can usually get it to run WOT without issue. Suspecting that the wires dry out once the motor comes up to temp...
What do you guys think?
