Quick Carburetor Question - HELP!!!
highballin
Motor: 1988 Mariner 45
Symptom: When I pump the primer bulb until its hard everything is ok... If I squeeze the primer bulb some more then fuel will squirt out of a hole inside a screw located at the top of the carburetor. This only happens when I am squeezing the primer bulb pretty good.
Is this normal?
Dan
Re: Quick Carburetor Question - HELP!!!
That would be your carb. bowl vent doing what it's supposed to do. Don't squeeze so much.:cool:
