quick check for a charging system ?
starcraft240
i have a 1987 88hp johnson v4 i was wondering if there was a way too check a charging system i checked at the battery and the meter showed 12 volts with the engine running or not. how long does the engine have to run before it begins to charge?
ezeke
Re: quick check for a charging system ?
Put your DC voltmeter's contacts directly on the battery terminals with the motor off, then with the motor running at over 1000 RPM read it again at the battery.
A healthy battery will read 12.7 volts wwith the engine off, and the reading should rise to well above 13 volts with the engine running.
