Hi, I tested the compression on my motor but I did it one cylinder at a time with the other spark plugs still in. I've read that you should remove all plugs, THEN do the test. Little confused. Is there that much difference? I got a 120-120-119-120 reading when I did it.
Thanks.
'91 Johnson 90hp V4 Crossfire.
Thanks.
