quick computer question
Brent S
Hello all,
Is there an easy way to wirelessly hook a laptop up to our printer?
I failed at finding a store clerk w/ a clue today.
If the answer is "yes" then where do I go and what do I get?
Thanks, Brent
Jerryh3
Re: quick computer question
What version of Windows are you running? You should just have to go to the "Add printer" icon and select network printer.
tx1961whaler
Hello all,
Thanks, Brent
Is the printer wired up to another computer? How is it connected?
Brent S
window xp to answer your question Jerry.
Adding the printer with a wire is not a problem, it's the wireless part I'm not sure what I need.
Brent S
you guys are fast and I thank you!!
It is connected with a usb cable to our desk top.
Jerryh3
Did you turn printer "sharing" on?
Brent S
Will turning the sharing on solve the wireless problem?
It works with a cable just not wirelessly.
Jerryh3
Turn on sharing, then try to add the printer using the laptop.
gonefishie
You need a printer with a wireless network card in it. Otherwise, it ain't happening.
like this
tx1961whaler
I can't do it on this laptop, since I can't join my Home network (where my printer is) due to the company group policy that I'm forced to live with.
Jerryh3
like this
Not really true. If the printer is connected to another computer on the home network, you can share and print from other computers on the network, even wireless ones.
Jerryh3
I'll try it, thanks
Let's back up one step. Is the laptop connected to a wireless router or access point? Is the computer with the printer connected to the same router?
dellsboater
If he is not allowed to change his network name on the work computer, it will not see the home network.
gonefishie
That's true. He would have to set up a home network and leaves the desktop on all the time. Or, turns it on when he wants to print from the laptop.
dellsboater
Nice...but the average home user does not have print servers or wireless printers, or printers with cat 45 ports, but they could add one. Wireless printers not connected to a router could work with an ad hock network. Can be tricky to set up but works well.
MTboatguy
None of my printers have network connections, they are all USB devices, the link that I posted is to a USB compatible wireless print server, which is a bit different than the one I purchased a couple of years ago...but still works on the same idea
Brent S
Thanks MTboatguy and everyone else. The product you linked to is what I thought I would need. I just didn't know if it existed. This should allow my wife to print directly from her laptop and not have to go through this dinasour.
There is a wireless internet router in the house that she uses but to print she has to use a flash drive and put things on here and print them.
Just tryin to make Momma happy!! ( and we don't even have kids)
PiratePast40
The wireless print server will certainly work but is a bit of a workaround. Inkjet printers have a life expectancy of about 3 years so if you're getting near that point, you might want to take a look at buying a printer with wireless capability and do the job right.
With either one you'll need to add the device and it's drivers to your existing system so the work to connect is probably about the same.
