QUICK EZ QUESTION - Regarding Rocker Arm Nuts
incrediblened
Would you use thread lock when you install the rocker arm nuts? The manual doesn't call for it, but I want those suckers to stay in place! :)
1997 Mercruiser 4.3, Vortec, 20ft/lbs torque on rocker arm nuts + thread lock?
jerryjerry05
Re: QUICK EZ QUESTION - Regarding Rocker Arm Nuts
No,they should stay in place.Unless you have had them on and off so many time they have stripped out.J
zbnutcase
Just use new, correct nuts and you won't need loctite.
BAproject
thread locker will just make it more difficult to adjust if you need to
Adirondack
What 20ft/lbs of torque are you talking about? Last I knew they were adjustable valves.
incrediblened
There is a difference between rocker-arm nuts on a 1997 and an earlier 90's 4.3. On an earlier 90's 4.3, the studs have a lock nut that you tighten down until the push rod doesn't wiggle up and down, and then you turn the bolt another 1/2 turn. (If I remember right). On the 1997 engine, you actually just torque the nut down to 20ft/lbs.
incrediblened
Hey, I did it, and she runs GREAT! I torqued the bolts down to 20 ft/lbs and chose not to use loc-tite.
