Quick hub question
Strecker25
Hi guys, hope this is an easy one. I'm trading out our tired 14x19x3 SS Vengeance props for a new set of 14.5x18x4 black diamond aluminum (I know, but I can't afford new SS right now). This is on a 1998 Searay 290 Sundancer with T5.7EFI/Alpha GenII drives
Is it fair to assume the hub kit coming off the old props is also the correct hub kit for the new ones? It all fits together just fine, just making sure. The only difference I can see is that the thrust washer looks like it could ride on the plastic hub since it sits flush with the back of the prop, as opposed to on the vengeance where the hub sat further inside the prop and the washer would ride on the metal.
Thanks all
Yegboats
Yes you can use your hub kit from the vengeance. Same Same
