offshore79
- Joined
- Jul 22, 2011
- 30
Again, 1989 OMC 3.0 in a 20 ft Baja open bow, fresh rebuild that I had running finally for a short time.
Ive replaced coil, points, condenser, wires, plugs, rebuilt carb, good fuel supply and pressure, adjusted valve lash, I'm trying to time it to 1* BTDC but having trouble because of the running problem.
I can start it with throttle which spikes to 2000-3000 RPM before I can try to bring her back down, I get it down to around 800 and she runs for a bit and then about the time I get back to the timing light, it dies. I've been trying to figure this out for hours.
I just read a thread in the merc area that sound almost like what I'm seeing and they mentioned a bad coil. The recomendation was to connect a jumper between + coil and + battery. I tried this and happened to notice that my coil was extremely hot.
***So my question is, is this an indicator that the coil is bad (did I cook my new coil) or that something is shorting making it hot and the coil is still good***.
By the way, I never finished the test because I ran the battery down trying to get it to start. Needs a charge.
Thank you
Offshore 79
Thank you
Offshore 79
