jjohnson120
- Joined
- Dec 31, 2009
- 278
I just bought a pontoon with a 2004 Honda 50hp. The motor has not been used very much and is in good condition. The previous owner let it set for awhile with old untreated gas. I had it out on the lake and it seemed to run ok, just a little rough at low RPM's, due to the bad gas I'm assuming. I did notice when I was out that at WOT or what should have been WOT the tach only showed 3100 RPM's but according to gps was running 21.5 MPH. After reading I notice that WOT is suppose to be 5,000 to 6,000 RPM's, so I'm curious if the anyone thinks the tach is not reading properly or I was legitimately only at 3100 RPM's due to bad gas?
Previous owner said he had speed at around 24mph but I honestly didn't know if 1900 RPM's respectively would make a 3mph or so difference. Any insight would be well appreciated.
