Quick question on winterizing this year..
Ron-O
On my 91 4.3 Mercruiser:
Every year, I usually pull the thermostat after draining the block and fill fill of RV antifreeze and put a new thermostat in (OCD I guess). I just had a new thermostat and impeller put in 2 months ago. Instead of pulling the stat this time, I could remove the water hoses and fill from there. The question is, which ones do I pull to fill the block?
Ron
dubs283
Re: Quick question on winterizing this year..
drain block and manifolds
remove the large hose on the stbd side of the t-stat housing
leave the two block plugs on either side of the block out
pour anti-freeze in the large hose until you see the antifreeze coming out both sides of the block
let the antifreeze drain out, reinstall plugs and hose - you're all set
its a good idea to pour anti-freeze down the water intake hose until you see it coming out the intakes on the drive too (backflush)
