Ha! Go figure, be too easy. I checked my timing and it advances nicely. I will be making some timing marks on flywheel or what can be seen easy, maybe a TDC, the inital setting and maybe a 18o. I'll have to check what the exact numbers are. Today I checked both my engines and they both moved the same on increased rpm's. I wanted to proof my Thunderbolt Electronic Module before I went further. My issue is not being able to get over approx 1400 rpm under load, at dockside rpm's increase nicely. C/O carb's between engines, replace dist cap and rotors, wires are in great shape but did check carefully that they go to the correct plug. The only thing I can think of now is the HT coil, thinking that plug resistance goes down under load maybe could be the culprit. I'll swap them over on the weekend. Any other suggestions would be appreciated.
