quick question?
cwilt
can someone tell what the effect of prop diameter has? keeping the same pitch, rake, and cup design.
Re: quick question?
Ayuh,.... Diameter is determined by blade design, 'n fitment to the motor...
Silvertip
Re: quick question?
If you are changing from a 15 inch diameter prop to a 19 for example, there would indeed be a change in rpm. However, a 19 inch prop does not belong on an engine designed to run a 15 inch prop and besides, it would not fit. It has to do with blade area. Much more blade area on a 19 inch prop than a 15. If you are comparing pitch differences within a given prop type (say 15P, 17P, 19P) the diameter will decrease slightly as pitch goes up, and increase slightly as pitch goes down. Those changes however generally amount to about 3/4 inch which means nothing other than it is part of the prop design for that particular series of engines.
cwilt
Re: quick question?
i was wondering because i see different props out there that are the same pitch but have different diameters. i would like to go to a 24 pitch or maybe a 25 pitch prop same make and model but the diameters change. i have a 23 pitch now. i can get my rpm's to 5700. (my range is 5 to 5.5 k)
