Quicksilver Corrosion Guard
wrvond
Anybody actually do this?
My manual says to "Spray power package components on inside of boat every 2-3 weeks with Quicksilver Corrosion Guard to protect finish from dulling and corrosion. External power package components may also be sprayed."
​I'm hesitant to spray anything on my otherwise very clean engine, especially anything oily.
s.hadley81
I've never use the quiksilver brand but I sprayed my oil pan and bottom of my engine with pb blaster corrosion stop and it collected dirt like crazy! I wound up spraying it with degreaser after about a month because it just made a mess.
wrvond
That's what I'm wanting to avoid.
Though it could be more like fluid film, which I don't think would pick up a bunch of dirt.
Fluidfilm or Boeshield are the two things I suggest
bspeth
I use Rem-Oil wipes on my engine before layup,and I haven't had any problem with dirt in there.
achris
More fish than mountain goat
Corrosion Guard used to evapoate to a thick dry film, but they changed the formula a few years ago and although it doesn't seem to dry out any more it doesn't 'collect dirt'. I would still recommend it. It's still one of the best corrosion barriers I know. And if you're looking for the best water-proof grease for submerged components, try 'Aqua-shield'. (and when you buy a case, send some my way. ;) We can't buy it in the land of Oz :()
Chris.......
