My quicksilver tach isn't working and I'm wondering if I can run a wire directly from the tach to my 1984 mercury 90hp 6cyl? The way it is setup now, the tach signal wire leads into my quicksilver controls, and from there they go back to the motor. At one point someone did some monkeying around with the wiring on this boat. It starts and runs fine so I haven't paid much attention to it until now. Can I run a wire directly from the tach to the grey wire on my motor connector? I looked at the wiring diagrams posted at maxrules.com and they show grey as being the wire used for tach signal. The diagram itself shows the grey wire going to the rectifier so I just want to be sure this is the correct wire? I would just like to try bypassing the tach signal wiring in the boat in case it's disconnected somewhere that I can't see. The tach itself is getting power/ground, so either it's the tach signal wire, the tach itself is shot or not compatable with this motor. The selector on the back of the tach is set to "12 pole alter" which I think is the correct setting for a 2-stroke?
