Quicksilver throttle control loose
thedillybar
I have a Quicksilver panel mount throttle control. The manual is here (thanks Don S) http://www.4shared.com/account/file/48885382/2933ae0b/Commander_Panel_Mount_sec04.html
The throttle control is loose to the point where it no longer engages. The plasting "bezel bushing", labelled part #22 has slid & worked its way out of the control.
I have followed the Disassembly section of the manual, but am still unable to remove the control handle. Specifically removed cover, removed throttle-only button, and straightened trim wires so they protrude straight-out from the hub. Any ideas?
thedillybar
Re: Quicksilver throttle control loose
The solution was WD-40 and lots of pulling until it came off
