Quiet Motor
birdman55
I have a 1979 johnson 70hp. I removed the foam from the inside of the cover and replaced it with thicker foam, fit's very tight. Any problem with this? The air breather is still clear. Thank birdman55!!:confused:
kenmyfam
Re: Quiet Motor
As long as the plug wires do not short out on it you should be O.K. However if it was a good idea I think the manufacturers would have done it to be able to claim "the quietest outboard in it's class"
Is it fireproof ??? if not then bad idea !!!
kenmyfam
Re: Quiet Motor
Any new foam would likely better than foam that's been soaking up fuel vapours for the last 30 years.
Disagree. Do a test with some cheap and cheerful foam you get at the dollar store and let me know how you make out (after you get out of the burn unit)
