Quit your whinning!! Tilt motor noise??
mrcool
I have a 1984 Evinrude 90 with tilt and trim. It worked great all summer but the last two times out the t&t motor sounds louder and seems to whine more than normal while raising the engine. Going down the sound is the same as always. Is this sign that the oil may be low? if so where do you add oil?
mikesea
Re: Quit your whinning!! Tilt motor noise??
yes,the oil resovior is opposite the tnt motor,it has a large screw in the side,remove it and fill with tnt fluid til it overflows,operate the unit a few times and recheck fluid
