Re: R Brake Light & R Headlight trailer wiring
The avalanche has the bracket installed, previous owner never used, so hopefully the truck wiring is OK. I figured it was a ground issue, I checked them to make sure they are tight, I will strip the wire ends and reapply terminals etc. It's wierd it's only one side goes out when headlights are on then brakes applied though.
Thanks for the replies
