r&r engine
whathappened
1978 mercruiser s 4945740 , 350 cid chevy , pulled motor last year and just got rebuilt , did'nt take pic or tag parts , got clymer manual , but no pictures , need to no if anybody has a picture of this motor which will show power steering pump , gas filter placement on engine , eyes are going bad from looking at this mess i got myself into , thanks in advance
whathappened
Re: r&r engine
hello fellow boater , if there is'nt any pictures out there of this engine , coulld some 1 please draw me something that would help me out of this mess , it's like i i'm missing some parts and i never took anything out of the boat , thanks in advance , this motor is setting in a 24ft well craft
whathappened
Re: r&r engine
thanks for the heads up on the link to the manual , i do apreciate the link , but sort of just wanted a pic of the bolt up of power steering and fuel filter , doing this project for my neightbor , he put the engine in and he wanted me to hook up the external parts and wires , cause i pulled this engine and got in a hurry and di'nt tag and take pic , got a clymers manual , just can't remeber about these 2 parts and there hookup , i'm not very puter savey and this is abig down load , so just a pic or a drawing would work for me , if this is not a big down load let me no and i will do it , thanks , also where is this manaul loading to , when i click on link it just starts down loading , don't give me a obtion to where i want to save it to ???????
ziggy
Re: r&r engine
have yer friend help ya down load the real service manual so ya can get his boat right. ditch the clymers.... it don't have all the info ya need in it. the mercruiser sm does though. yep, the file is 1.36GB. so it is large. nothing different about loading a large file vs a small one other than it takes time.
if ya really don't want to download it... get the book. try ebay or there's always the dealer... very expensive though..... sure makes the link look real good...... looks like you need service manual #3, part number 90-95693
whathappened
Re: r&r engine
ok thanks ziggy , i do thank both of u for your reply and will do the down load , neightbor lives 150 miles away , so no help right now , he is a weekend warrior ,
Fishermark
Re: r&r engine
Instead of simply clicking on it, use the right mouse button to click on it - some options will pop up, one will be "save target as" (or something similar, depending upon what browser you are using). Choose that option and you can pick where on your hard drive to save it.
Regarding you specific question, I would suggest you use Google and search the images of boat engines.
littlebookworm
Re: r&r engine
I've got my 5.0 Mercruiser, basically the same as the 5.7, sitting on a dolly in the garage. I can shoot pictures and email them to you, if you want. I don't know how to upload them to this site. Do you have the high mounted or low mounted power steering pump? Mine has the high mounted. Are you talking about the gas/water separator when you say gas filter? Let me know. Post your answers and include your email and I'll get back to you. I'll go shoot some pictures now. Hy
whathappened
Re: r&r engine
thats the problem i don't remeber how i unbolted this power steering pump , the belt for it is a short 1 , so it mite be the lower mount , but when i bolt er to engine it makes fill hole tip in to far and there is no room to move it for adjustment , so it could be high or low , and the filter i'm talking about is the gas water seperator , so yes if not to much touble for ya , i would like to see a pic , wllm_culhane@yahoo.com , thanks in advance , just looked at email and there is a upper case under score between wllm and culhane , ya can't see it with the line under my email addy , thanks mate
mkast
Re: r&r engine
Take a look at the online parts vendors, many have pictures.
The exploded views will show assembly.
whathappened
Re: r&r engine
ok mates have talked to grandaughter in fl. and she said load this manual on a zip flash memory card , so waiting for wife to get back to me with the zip drive and i can dowload this manual , thanks for all the headup replys , will let ya no what happens
whathappened
Re: r&r engine
thanks for that link bondo , it was sure worth it , when neightbor put engine back in he did'nt put hydro hoses on the right side of motor mounts , so i was trying to mount engine on starboard front of engine , when i got manual down loaded , 11hr download , the picture was there , had to un hook hoses from pump and reroute them and to port side of engine boom i had pump mounted , now trying to find a pic of slave sleliod and location of some of the wires coming from the plug in , thanks for that link , was worth a million ,and thanks to all that chimed in
Re: r&r engine
Ayuh,..... You're Quite Welcome,.....
That post makes it worth the time for Us who do it......... ;)
