Rack steering cable
skipbehr
I installed a new rack and pinion steering cable to replace the broken one,and it seems the helm gear jams when installed. The gear seems to go into the rack too far. Is there a possible remedy or do I replace the helm gear.
I am sure everything is put back properly?
danintruder
from what i learned repacing mine with seastar double cable
rack kit the instructions stated that new cables do not fit old helm station (wormgear) so have to be changed as a kit. maybe thats your case.
Ayuh,.... Which is the reason the helm, 'n cable should be replaced as a set,....
skipbehr
That was the problem had to replace helm as well as cable thanks
